Coolant flush/change
Old Mar 29, 2005 | 09:37 PM
stutterstan's Avatar
stutterstan
What is the best way to change/flush the coolant in the radiator? How many gallons of coolant is required? BTW, its a 93 F250 with a 351W
Old Mar 30, 2005 | 12:25 AM
bigredsbronco's Avatar
bigredsbronco
best way depends on how bad you think it is. if its just time for it, you should flush it with a flush tee in one direction until it flows clear with engine running, problem is it usually won't get warm enough to open therm. so I remove the thermostat first flush it out then replace with new thermostat. takes 15 qts w/o a/c, 16 qts w a/c, and 17 qts with a/c and super cooling
