Rear end ratios trivia question
Old Feb 22, 2001 | 04:04 PM
leggman1's Avatar
leggman1
I have a 83 f100 with a transplanted 302 and a c6 trannie. The tag on the rear end says 3.50
I turn 3,000 RPM at 65 mph with 31 inch tires.
Question is if I put in the 3.25 carrier I have extra in the shop how much will my RPM's drop at 65 Mph.
Please help. The mileage is killing me. Thanks.....Dave
Old Feb 22, 2001 | 04:46 PM
brown 4x4's Avatar
brown 4x4
Are you sure it's a 3.50 rear end? According to my calculations, you are turning closer to 2500 at 65 with 3.50 gears. 3000 sounds like you've got 4.10's. With a 3.25 gear, you should be turning around 2300 at 65 (plus any slippage from the auto trans.
Old Feb 22, 2001 | 05:12 PM
StrangeRanger's Avatar
StrangeRanger
I ran the numbers, came up with the same answers as Brown 4X4.
Old Feb 22, 2001 | 06:16 PM
otto's Avatar
otto
Old Feb 23, 2001 | 08:34 AM
rocky50's Avatar
rocky50
I have a 85 w/ a 95 302HO crate motor, C5 3-sp. auto, 3.08 rear end. I'm turning 2600rpm at 65mph. 255/70/15 wheels. If it weren't for the 3.08 rear I wouldn't get on the hiway. I really need a AOD and a 3.55 or so rear.
Maybe you need a 3.08 to go with your overdrive tranny?
Moe
Houston
Old Feb 23, 2001 | 08:39 AM
rocky50's Avatar
rocky50
Sorry about the "overdrive tranny" part. I got confused.
I thought my RPM's were bad. Get a 3.08.
Old Feb 23, 2001 | 05:50 PM
StrangeRanger
He's running 31" tires vs. your 29." For him a 3.25 will be about equivalent to your 3.08s.
