Some time ago on this post someone mentioned a component that could be purchased through Ford that allows adjustment of the minimum airflow through the IAC, with a needle valve I believe. It is supposed to help with rough idle problems. This is for a 89 F150 with 5.0L. Any help appreciated.
Thanks
mjb1962(No Email Addresses In Posts!)
[font size="1" color="#FF0000"]LAST EDITED ON 13-Feb-01 AT 11:24 AM (EST)[/font][p]I believe the part you're looking for is F2PZ 9F93 9A . I was quoted $19.10 and my dealer carries them in stock. The kit is supposed to have a plate that mounts under the air bypass valve, longer screws, labels, gaskets & instructions. The plate has 2 adjustment screws that allow you to adjust the amount of extra air that gets bypassed.
What is the theory behind this part you are adding? I often
wondered about the whole throttle body setup. The computer
tries to keep the engine at a certain rpm at idle right? If you adjust the throttle cable stop, affecting the throttle butterfly closed position, wouldn't this move the idle air bypass valve postion?
If you closed the throttle body more, wouldn't the bypass valve open more to try to maintain the computer's set idle speed? This would also affect the output voltage of the throttle position sensor which would affect trans convertor lockup among other things? If you add something else in the picture, where
do you start?
the idle air control valve really doesn't control the idle, but helps control the mixture at idle. The idle speed is detirmined, like in any car, by the position of the throttle plates. The IAC merely lessens any fluctuations in air volume that would pass through the throttle body. The computer has an idle speed in mind, but it really can't control it. (my idle can vary from 575-750 depending on factors outside of the load on the engine.)
The important thing to remember is that in a modern fuel injection system, it's hard to find ONE thing that controls ONE operation. Multiple sensors and acctuators go into achieving one operation. If you really want a good book to read, pick up "Ford Fuel injection and electronic engine control" ISBN# 0-8376-0301-3. 400 pages of fuel injection goodness...
hope my rambling helped...
1989 F-150 : 5.0, shorty headers, Flowmaster cat-back, K&N filtercharger intake, March pulleys, "Multi-brand" performance ignition, soon to be Mass-Air...doesn't know she's not a Mustang
>control it.
The IAC valve allows air to bypass the throttle plate. The ECA varies IAC duty cycle to control the idle speed. The IAC has no effect on the air/fuel mixture. Mixture control is achieved by varying the injector pulse width.
In addition to what Knuckles added , the Part in question was originally designed for throttle bodies that werent supposed to be cleaned or have any chemical agents to clean them due to a coating on the inside of the throttle body which was supposed to keep them from accumulating any carbon deposits . If the idle speed control is clean & the throttle plates are clean then the idle should be within specs . Often times if the throttle plates & or the idle speed control have not been cleaned for an extended period then they require extensive cleaning / carbon removal for them to operate as they should .
True, you are fighting the software idle speed regulator in the computer but the idle speed at times is too low and somewhat rough. I am thinking that this additional airflow at idle will prevent the controller from dropping the idle speed so low. It will also leave the throttle valve cable adjustment to the auto transmission unchanged.
Thanks for your help
Mark
Speaking of IAC valves, someone mentioned to me that i need to clean mine (89 5.0) to stop the surging when first running in the morning. Could someone tell me how to go about doing this?
