u joint problems
Old Mar 29, 2005 | 04:54 PM
wagon5.0's Avatar
wagon5.0
u joint problems
does anyone know where i can buy the cv joint that is located on the end of my high boys drive shaft there are two ujoints in a coupler and the needle bearings are gone out of the cv joint Thanks
Old Mar 29, 2005 | 05:57 PM
ivanribic's Avatar
ivanribic
You don't need to replace the CV, just the u-joints. Your local parts store should sell them. I got mine from Napa, it's basically just 2 seperate U-joints that make up the CV. I think they cost me $12 each. I'd recommend taking the u-joints in there with you when you buy replacements so they can double check to be sure you have the right ones.
Welcome to FTE!
