headlamp problem
Old Mar 29, 2005 | 02:55 PM
JICASE's Avatar
JICASE
headlamp problem
I have a 95 crew cab dually stroker that started having a head lamp problem. The problem is after the lights have been on for about fifteen minutes on bright the headlamps start blinking. It is almost as if they have a flasher built into them. They do not do it on the dim selection and it is only the headlamps not the running lights or tailights. Is there a relay in the line somewhere or is my switch the culprit? I just replaced the switch about 6 months ago and this just started this past weekend. What the heck could it be? I appreciate the help. Jake
Old Mar 29, 2005 | 07:23 PM
barebackjake's Avatar
barebackjake
sounds like a bad relay, theres a headlight relay could bypass that and see if it cures it. it one of the relays on the passanger side by that battery.
