Colorado Chapter Join Chapter, Leader:
Good junkyards to find parts for a '76 F-250
Old 04-10-2005, 01:52 AM
MineralStang's Avatar
MineralStang
MineralStang is offline
Question Good junkyards to find parts for a '76 F-250
Hey everyone just wanted to see if anyone knew what junkyard was best in the Denver area to get some wiring harnesses off of (Duraspark I). If you want some background on my issues here is the thread:
https://www.ford-trucks.com/forums/s...d.php?t=361118
I'm looking for a complete ignition wiring harness from the ignition box to the coil and then the distributor. I'm also looking for some other wiring as well. Just wanted to know what yard I may have the best luck in. I have a '76 F-250 with a 390. Thanks!
Nate
Old 04-10-2005, 12:45 PM
EJL96PSD's Avatar
EJL96PSD
EJL96PSD is offline
One that I have visited a few times is Svigles Auto Parts on the west side of Santa Fe, just north of Oxford from what I remember. Its right around in there. They specialize in American Cars and Trucks. Sorry I don't have Svigels number, I do know its in the phone book. Hope this helps.
Old 04-10-2005, 01:03 PM
MineralStang
R they a pull your own type of junkyard? Or have they pulled all the stuff already? Thanks!
Nate
Old 04-10-2005, 02:05 PM
Hypoid's Avatar
Hypoid
Hypoid is offline
Pull-n-Save is hit or miss. Have you checked the "parting out" section of our local classifieds?
I read through your thread, not convinced that replacing the harness will solve your problems. The ignition switch is highly suspect, especially if original to the truck.
I have wiring diagrams, test procedures. If you can use them, I'll scan some jpegs and email later-someone elses turn at the puter.
Mike
Old 04-10-2005, 06:09 PM
MineralStang
Talking
Yeah.....I'm kind of suspicious of the ignition switch. When I get in I can tell if it will start or not depending on the ignition switch and the way it behaves with the trying to start fine or the "trying to start" between run and start syndrome. If I get in and I attempt to start it and it behaves normally, it will start but if I attempt to start it and it coughs between start and run It won't start. Hope that makes sense. I would love any info you can give me Mike would be great! I'll PM you wih my e-mail address. thanks everybody!
Nate
P.S. I'm at work (going home now cuz we closed early) and I tested the truck and it started right up. MAN...this is the kind of weather my beast needs to be in...can't wait to get this issue resolved.
Old 04-11-2005, 10:41 AM
Mike G's Avatar
Mike G
Mike G is offline
I usually shop at Colorado Auto Salvage, they are just down the street (Radcliff) from Svigels. Located just West of Santa fe and South of Oxford. It is a pull your own, if they have they type place. I was just there last week and they do not have any Duraspark FE systems. Now they do have the Duraspark systems, but are on other engines. They will work as well, just need a different Distributor.
--Mike (G)
real31
1999 to 2016 Super Duty
09-10-2013 03:35 PM
MineralStang
81
06-04-2006 10:57 AM
MineralStang
Aftermarket Products
08-03-2005 07:21 AM
MineralStang
Colorado Chapter
06-26-2005 06:37 PM
MineralStang
Electrical Systems/Wiring
03-22-2005 10:27 PM
Quick Reply: Good junkyards to find parts for a '76 F-250
