Sensor Q?
Old Mar 29, 2005 | 10:41 AM
systemofadowntox's Avatar
systemofadowntox
Sensor Q?
Howdy,
I just bought a 1988 f-150 4x4 with a 302 efi. it startet to run a little rough so i took a wire off of a sensor under the air cleaner hose. i hit the sensor with a wrench and it fixed it. Does anyone know what the sensor is called? i need to order a new one
Old Mar 29, 2005 | 12:12 PM
EPNCSU2006's Avatar
EPNCSU2006
Do you have a picture?
Old Mar 29, 2005 | 12:34 PM
chrono4's Avatar
chrono4
under the air cleaner hose? on the throttle body? maybe the throttle positioning sensor.
Old Mar 30, 2005 | 10:35 AM
systemofadowntox
would the throttle positioning sensor make it run rough?
Old Mar 30, 2005 | 11:25 AM
EPNCSU2006's Avatar
EPNCSU2006
It is possible. Have you tried pulling codes from the computer?
If not, give it a try and see what codes come up. http://fordfuelinjection.com has instructions under "initiating a self test"
