changing clutch
Old Mar 29, 2005 | 06:28 AM
bigdaddyII's Avatar
bigdaddyII
Post changing clutch
fixing to change my clutch in the next couple months or so and i have never done this before, but i figure that it is high time that i learn. can anyone provide me with a step by step and a list of tools needed. thanks
Old Mar 29, 2005 | 06:56 AM
teds74ford's Avatar
teds74ford
Your best bet is to get a shop manual. However, here is a quick rundown. There is bellhousing bolts that go to the engine block. Mine has 6. You need to take the driveshaft out, and the crossmember. Remove the shifter. Disconnect the hyd cylinder. Remove tranny. Now, I would suggest getting all new parts, and having the flywheel resurfaced. To get the bushing out of the crank, I have used grease and something that barely fits in it. YOu can hydraulically force it out. Inspect the engine rear main seal to make sure it isn't leaking or you will need another new clutch soon. THen reassemble it. The book will tell you what to torque everything to, which it important. Good luck.
