Sponsored by: Real Truck
Got my 4.30's!!!!
Old Mar 28, 2005 | 07:52 PM
Brian460's Avatar
Brian460
Got my 4.30's!!!!
I love them. Since I blew out my rearend and had to replace the case and all I decided it would be a good time to go from 3.73's to 4.30's.
It did not affect the mileage good or bad and it only raised the 70mph rpm by 300rpm.
Can't wait to pull the trailer with it I have a feeling I may see a slight increase in the mileage with a loaded trailer compared to the 3.73's.
Just thought I would let you all know incase somebody else was thinking about lower gears.
Old Mar 28, 2005 | 11:18 PM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
Brian,
I have installed 4.30's in several 6.0 trucks, (including my own) with tires in the 35" (315) to 38" range. I think it is definitely the way to go. You will love the way it tows.
have a great day!
Tim
Old Mar 29, 2005 | 02:36 AM
569104's Avatar
569104
I too have 4.30's with 35" tires and love improved bottom end and better driveability.
Old Apr 18, 2005 | 02:08 PM
anthracis's Avatar
anthracis
I am getting 4.30s on FRIDAY!!!!!! Yeah!!!
2001 F250 SDY Supercab Running 4" lift and ProComp Mud Terrain 35s.
Old Apr 18, 2005 | 02:26 PM
tps0424's Avatar
tps0424
Where do you guys get your 4.30? From the dealer? What does it cost? I assume that you need to do the front too since all of you have 4wd.
Old Apr 18, 2005 | 03:42 PM
ttsupra94's Avatar
ttsupra94
I would also like to know the answer to the questions posted above. I just bought an 8" lift and am probably putting 38x15.5x18's on. Wondering if i need change gears. It's a diesel and i never ever tow or haul anything. Do I still need them?
Old Apr 18, 2005 | 04:21 PM
mwpierson's Avatar
mwpierson
I just had 4.30s installed too with my 315/75/16s and 4" lift. It makes city/highway driving much better. The gears didn't change my already bad mileage due to the 35s. However, towing up any long grade or hilly terrain still totally, TOTALLY sucks. The 4.30s and 35s only give you like a 3.92:1 ratio which *is* closer to 4.10s but not enough to give you WOW. My V10, can't drive up any grade in 3rd gear. It goes a couple of hundred feet, drops to 2nd until it gets to a higher RPM (if it can), then drops back to 3rd... then drops about 500rpm lower (yes, OD is off), then I hit the gass and it goes back into 2nd. Forget 3rd and manually drop it to 2nd. Then it wines at 4000RPM and I'm doing 50.
My TT dry weight is 5600lbs and loaded with gear and with water is about 6500lbs.
I'm seriously thinking about going all the way back down to 265/75/16s so I CAN tow.
BTW... it costs about $1500 for front and back. Fronts are DANA 60s and the rears are Ford 10.5
Mike
Old Apr 18, 2005 | 09:30 PM
Brian460's Avatar
Brian460
I had mine done at the local shop, can't tell you exact price cause I had a whole (like entire) brand new rearend put in (I cracked my case). Love the gears, never had a problem towing before (19,500 pounds trailer weight) so I imagine it will be even better now. My is a 6.0 PSD.
BTW some V-10's come with 4.30's stock so I would have gone with 4.88's or maybe 5.13's with a gasser.
Old Apr 18, 2005 | 09:32 PM
Brian460's Avatar
Brian460
Do you drive off-road? You may like 4.30's or even 4.88's with that tire size.
Edit: What body style is your truck? I assume you have a mid 90's body style with a 7.3psd?
Old Apr 18, 2005 | 11:45 PM
ttsupra94's Avatar
ttsupra94
Nope, not really any off road driving. its a 05 F350 CC SB PSD 6.0L with stock 3.73's
Old Apr 19, 2005 | 09:02 AM
anthracis's Avatar
anthracis
Getting mine done at West Coast Differentials in Northern California Sacramento area. Cost = $1,400 approximately is what I was told for all gears front and rear. My SDY was very, very, very sluggish off the line and it still is after Hypertech (but much better than it was). I also have flowmaster and FIPK installed. Hopefully, the 4.30 gears will get some off the line torque back. Next mod: headers! Then, supercharger!
Old Apr 19, 2005 | 06:47 PM
Brian460's Avatar
Brian460
Are you running any kind of chip or tuner? That tire size and stock program might feel kind of ******* with stock gears.
Old Apr 22, 2005 | 02:35 PM
mattsf250's Avatar
mattsf250
i cannot imagine a v10 or 5.4 with 35's.going from some of the replies in this post.....i stay in od with the converter locked, up an 8% grade at slow as 55 mph.... about 1400 rpm, maybe slightly less....and i want 4:30's!
maybe i should just skip and go with a 4.56??????
i do actually use my truck off road, as often as possible......that reminds me, supposed to ran sat and sun.think ill go find some mud!
Old Apr 22, 2005 | 05:17 PM
2000silverbullet's Avatar
2000silverbullet
I went right to 36's and then 37's on my v10 and it killed it with the 3.73's. I've since learned to live with it though. Gears are last on the list of things to do, but when I do, 4.88's here I come!
Old Apr 22, 2005 | 08:24 PM
ttsupra94's Avatar
ttsupra94
Yes, i have a predator.
