Sponsored by: Innova
Mark audio system help
Old Mar 28, 2005 | 11:54 AM
t_man1150's Avatar
t_man1150
I have a 97 Eddie Beaur Expedetion with a Mark audio system. The speakers no longer have sound I have checked bot fuse panels and all fuses are good. The radio lights up and changes channel and the 6 disc changers functions all work however I get no sound is the a amp or something in the dash that may have a fuse I can not get to or see?? or something else??
Old Mar 28, 2005 | 08:06 PM
Rob78357's Avatar
Rob78357
the radio either burnt or u need to check the wires to your RCA wires in the back of your radio and the speaker wires.
Old Mar 29, 2005 | 06:28 AM
t_man1150's Avatar
t_man1150
Correction the audio system is a Mach Audio system. I have pulled the stock radio and find nothing burnt. The radio funtions work just no sound. I have also found an factory amp for the sub in the rear of the vehicle that will only pass signal when it has power. I have located a similar looke device in the dash but can not get to it without tacking the dash out. I was wondering if anyone knew if that was an amp or if there was a more detailed book on the vehical that might cover this area.
