Offroad & 4x4
Roll cage?
Old Mar 28, 2005 | 11:52 AM
Nenzel's Avatar
Nenzel
Roll cage?
I have a 91 f150, with no license for 4 months, I want to build a in cab rollcage. I have taken welding all through high school. My dad is buying either a lincon, or a miller. My question is. How do i bend the tubing, i was thing a home made jig? any tips would be helpfull.
Old Mar 28, 2005 | 12:05 PM
ivanribic's Avatar
ivanribic
You really need a tubing bender for the job and for the wall thickness of the tubing you're gonna want it'll need to be a hydraulic bender. I've seen guys piece roll cages together with straight sections of tubing and weld them up but this is not near as strong and leaves a lot of points for failure.
Old Mar 28, 2005 | 01:02 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Make some friends at the local exhaust shop.
Old Mar 28, 2005 | 05:06 PM
fishmanndotcom's Avatar
fishmanndotcom
NO DO NOT USE PIPE BENDERS.... a pipe bender will pinch the bends and weaken the structure. obviously the best way is also an expensive way... either a Pro Tools 105 tube bender or JD bender would be the best but there are other ways. you know you can order weld in kits from places like Jegs and summit that comes pre-bent.... all you gotta do is fit it, trim it, and weld it!
-cutts-
Old Mar 28, 2005 | 06:00 PM
ivanribic's Avatar
ivanribic
Not that I know, so I'll ask. Some muffler shops can do mandrel bends. I know mandrel bent tubing doesn't pinch or flatten out like a pipe bender. If you could find a muffler shop that does mandrel bends and could use their equipment this would work okay wouldn't it? It's just the regular "pipe" benders you want to avoid.
Old Mar 28, 2005 | 08:05 PM
fishmanndotcom
muffler shops that do mandrel bends can't bend .120" thick wall tubing! also.... i *believe* mandrel bends aren't meant for structural duties!
-cutts-
Old Mar 28, 2005 | 09:47 PM
BroncoRoadKill
Sorry bout that, I meant too say mandrel pipe bender. But I did forget that most of these machines are not rated too bend thicker pipe.
Old Mar 28, 2005 | 09:55 PM
fishmanndotcom
no biggy, i would just hate to start seeing exhaust tubing roll cages with pinched bends!
-cutts-
Old Mar 28, 2005 | 11:43 PM
mustange70's Avatar
mustange70
Or you could buy tube with bends in them already through a steel and pipe shop, then weld straight pieces of pipe in thier to get the shape right, grannted this might not be the best for strenght, or the scrap shop might be able to bend the tube for you.
flyin 51
Oct 4, 2012 12:01 PM
crehberg
The Next Generation
20
Sep 4, 2007 04:27 PM
Menroid
Sep 25, 2004 07:30 AM
teederj2002
Feb 16, 2004 10:45 PM
