wireing problem with dash insterments
Old Mar 28, 2005 | 12:50 AM
ray_bone40's Avatar
ray_bone40
i was working on my speedo cable that took too long to put in well any way as soon as i got it in my gauges didnt work so i went underneath foud this black wire with red stripe on it and had a connecter on it with no wire so i found a blue wire that has two wire together and hooked it up to it and it workded but at night with i turn my lights in my guages go to 0 or dead any answers going on here?????????????????????????
Old Mar 28, 2005 | 03:34 AM
ZombieSlayer's Avatar
ZombieSlayer
You should get a wiring diagram for your truck.
What year is it?
Old Mar 28, 2005 | 05:51 AM
William's Avatar
William
I'd unhook that wire! Your gages should receive 12V with the key on through the constant voltage regulator which drops the voltage to the individual gages to about 5 volts. You need to locate a 12 volt ignition switch controled source to connect to the gages. There should be a black ground wire running from the metal back of the cluster cluster to the steering column support. I usually replace this wire with a longer one because it is to short to allow working on the speedo cable and usually gets ripped off anayway.
Old Mar 28, 2005 | 10:34 AM
Al_V's Avatar
Al_V
Right here:
http://www.tocmp.com/tOCMP/wiring/1964F100/index.htm
