SES question
Old Mar 27, 2005 | 07:03 PM
Superunatural's Avatar
Superunatural
SES question
Is the truck defueling the whole time the SES light is on or just while the truck is overboosting, how many lbs of boost triggers it and how much further until I'm pushing the stock turbo? Can someone post a link on how to get rid of the SES light?
Old Mar 27, 2005 | 07:46 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Once the SES light is triggered for overboost the PCM will stay in the lower fueling map until the next drive cycle. 24 psi triggers the light on 99-03 trucks, I think it's 22 osi for the 94-97's. The journal bearings in the stock turbo are manufacturer rated for 25 psi.
To kill the light: http://www.itpdiesel.com/OverboostKit.shtm
You'll cave to copy/paste the link into a new window.
Old Mar 27, 2005 | 09:03 PM
Superunatural
Thanks for the link. Mine is a 01, so if I can only run 25 lbs of boost and I'm hitting 24 there is no sense in killing the SES light, right? Does the defueling keep you at or around 24 lbs or does boost suffer alot. Just wondering, if defueling drops the boost down alot if it would make more sense to back off on the power so I can run as much boost without triggering the SES. If this is as fast I can go with the stock turbo that thing is outta here. Any suggestions I hate doing things twice so whats a good turbo that will do anything I want it to do without compromising the stock internals.
Old Mar 28, 2005 | 11:48 AM
cookie88's Avatar
cookie88
FTE Emeritus
You can run more than 25psi, that'sjust Garrett's rating. Many folks around here that routinely surpass 30psi on the stock turbo.
I don't know your current mods so it's impossible to speculate how far you can go.
The Garrett ball bearing turbo is a stock replacement upgrade that is rated for 40 psi and boltsin with no other changes.
Old Mar 28, 2005 | 02:03 PM
FAB150's Avatar
FAB150
An even easier way to kill the SES light is called a boost fooler. Its just a harness that gets plugged in between two connectors at the MAP sensor. Check out www.smokindiesel.com . That part isnt listed but call the number and for about 10 bucks (if i remember correctly) it will be at your door in like 2 or 3 days. I havent had any problem with it yet and my boost has been up to 29 lbs so far.
