Runs bad when cold
Old Mar 27, 2005 | 06:37 PM
rabalcer's Avatar
rabalcer
Runs bad when cold
Just bought a 1982 f-150 w/ the inline 6 cylinder, 4 speed stick. Start it up and have no problem with first roll out of the driveway but immediately runs VERY rough until it reaches normal operating temp.(about a mile) then it runs like a top. Vacuum advance problems? Thermostat? I haven't worked on a car in ages but this one looks reasonable to tinker with. Any help appreciated.
Old Mar 27, 2005 | 07:01 PM
yozsi's Avatar
yozsi
make sure the carb mounting bolts are not loose.
Old Mar 28, 2005 | 12:00 PM
MRStace84's Avatar
MRStace84
If you have an automatic choke, see if it is working. It could be not closing all the way or opening up to soon. Also check and make sure the foil tube that connects from your exhaust mainfild to your air cleaner is hooke up. There should also be a metal tube that connects to the exhuast manifold that connects to the top of the carb.
Old Mar 28, 2005 | 05:43 PM
Big Red's Avatar
Big Red
My guess is the dreaded carb icing problem. I have been plauged with it ever since I got my '83 302 eight years ago. At it's worst in damp weather at temeratures around freezing.... summer is not a problem. Make sure your heat stove and attached air snorkle and vacuum flaps are in working order. My setup is pure stock and all associated components have been replaced and is in working order but still have icing problems at times.
Old Mar 28, 2005 | 06:19 PM
ClydeSDale's Avatar
ClydeSDale
Sounds like a choke out of adjustment to me. I have the same problem with Clyde. When I set it up for cold weather starts it sometimes likes to fast idle at a stop when it's warm. I just readjusted it because it did just what you're describing; hard start, rough running initially with a lot of stumbling, etc until it warms up.
With the vehicle cold take off the air cleaner, being careful not to bump the linkage. When you manually open the throttle by moving the linkage the choke plate should snap shut. If it doesn't you may have to loosen up the locking screws and rotate the cover until it does close properly. It may take a little experimentation to get it right. I've always found this to be a bit of a trial and error thing. When the engine starts the choke plate should open just a bit, progressively opening further as the engine and choke heater coil warm up.
Not an expensive thing but it can be a PITA until it's right.
Good Luck with it!
Roger
