Oil sending unit
Old Mar 5, 2001 | 04:04 PM
seamanrecruitohms's Avatar
seamanrecruitohms
Oil sending unit
I have a 89 F150 w/302 4x4 5speed
At times it says I have no Preasure.
The temp gauge doesn't work.
When I lose presure it doesnt sound like it is knocking, it sounds normal. In 5th gear doing 30 @ 1000 rpms when I push on the gas I loose presure (engine light doesnt come on). In 2nd and in between shifts I will loose pressure and the engine light comes on but it sounds normal. any Ideas
Old Mar 5, 2001 | 07:34 PM
jakegypsum's Avatar
jakegypsum
Oil sending unit
It could be electrical. The voltage regulator or the ground to the guages could be going bad. To nip the possibilty of engine problems in the bud, I would get a mechanical oil pressure guage and screw it in place of where the oil pressure sending unit mounts. this will show your true oil pressure. After you know that the engine is OK, then I would go from there. good luck.
Jakegypsum // Ford fleet, soup to nuts.
Old Mar 7, 2001 | 12:49 AM
deleontow's Avatar
deleontow
Oil sending unit
Old Mar 7, 2001 | 10:19 AM
toecutter's Avatar
toecutter
Oil sending unit
Ya, and when you get one of those mechanical oil guages, make sure it has (or you can get) a tapered connection for screwing into the engine block....don't know how the 302's are, but I've had a helluva time trying to adapt the guage I bought to my 4.9....all because they didn't give me a tapered apapter...sheeeesh....
Phil
CrazyMiracleMan
13
Oct 16, 2012 03:35 PM
hardwaterfreak
Dec 22, 2011 07:56 PM
kentucky2000f150
1997 - 2003 F150
Feb 5, 2011 10:32 PM
ontario ford guy
Oct 19, 2005 06:28 PM
Joe
Dec 5, 1999 08:45 PM
