General Automotive Discussion
Torqueflite 727 fluid
Old Mar 27, 2005 | 11:03 AM
Cool1996's Avatar
Cool1996
I have a 1968 Chrysler Newport and i think it has a 727 trans in it. i was wondering, first, if it does have a 727 in it and if it does, how much fluid and what kind of fluid it takes?
Thanks Alot Guys!!!
Old Mar 27, 2005 | 01:37 PM
fordxxx's Avatar
fordxxx
Replace it with a C6.
Old Mar 27, 2005 | 06:50 PM
DaddyOutlaw's Avatar
DaddyOutlaw
Its either a 727 or a 904, more than likely a 727.
As for the fluid it takes Dextron Mercon III and it will hold 11 Qts dry and 5 qts for a filter change.
Old Mar 28, 2005 | 08:38 AM
bigdaddyTank's Avatar
bigdaddyTank
Big block or small block? If its a big block it would have to be the 727, that was the only auto for them, the small blocks used both versions though.
Old Mar 28, 2005 | 09:45 AM
oldhalftons's Avatar
oldhalftons
it takes dextron. It it has sat for any length of time run it in neutral before you put it in reverse.
Old Mar 28, 2005 | 01:24 PM
tomw's Avatar
tomw
You can't kill them if you change the filter.
Mostly the filter plugs with a small amount of goop... the pressure drops ... and then the clutches burn... and REALLY plugs the filter. Other than that, they'll last forever. They (both 727 & 707?) were excellent transmissions, and give very good service. Easy to work on, too.
tom
Old Mar 28, 2005 | 10:58 PM
Cool1996's Avatar
Cool1996
it has a 383 in it if that helps on what trans it has
Old Mar 28, 2005 | 10:59 PM
Cool1996's Avatar
Cool1996
daddy outlaw. with your fluid capacities, do you mean 5qts total if i change the filter or 5qts extra with a filter? i am going to drop the pan, put on a new gasket and change the filter. how much do i put in?
Old Mar 28, 2005 | 11:11 PM
oldhalftons
5 quarts
its definatly a 727 if its behind a 383
ryans88gt
Sep 28, 2015 05:29 PM
toby tough
Jul 28, 2015 07:33 PM
Slackdaddy
Apr 15, 2015 01:01 PM
longbedFord
Paint & Bodywork
Dec 17, 2014 07:35 PM
HILLBILLY BOB
Ford Truck Parts for Sale
Dec 16, 2014 11:43 PM
