Idle adjustment
Old Nov 15, 1999 | 08:05 PM
ray's Avatar
ray
Idle adjustment
Old Mar 7, 2001 | 02:58 PM
crab's Avatar
crab
Idle adjustment
How do I adjust the idle on an 85 F-150 5.0l FI?
Old Mar 7, 2001 | 09:05 PM
zemus420's Avatar
zemus420
Idle adjustment
Lift the hood you should see a big black cap right above the distributor cap you can't miss it, take off the cap there should only be 3 screws to take off the cap. Now once it's Off look for a screw with a spring through it that's the Idle control
Loose-Less Idle
Tight-More Idle
hope this helps
