gear shift ajustment
Old Mar 27, 2005 | 09:07 AM
strokeman's Avatar
strokeman
My 1995 F150's gear shift handle has some play in it and it is also out of alignment with the gear indicator. It has to be moved to the left of where it should normally be to indicate gear. How do I correct this problem???
Old Mar 27, 2005 | 05:07 PM
95X15's Avatar
95X15
Take the lower shroud off the steering column this will expose an adjuster - in Drive adjust to center on D indicatoin with 3 lbs down on end of gearshift. From 95 serice manual. Good luck.
