Sponsored by: Real Truck
Motor Knocking
Old Mar 26, 2005 | 07:57 PM
hdman6's Avatar
hdman6
Question Motor Knocking
I have a 2003 f-250 with the 5.4 motor. The truck just hit 39000 miles. I have the oil change at the dealer (free of charge every time) at 3000 miles. lately I have heard a knocking sound when i start it up and after the first mile it seems to go away. I'm not sure what it could be, Sorta sound like an exhust leak type sound, but since it goes away i suspect it isn't. Could it be a lifter problem? I purchased the extended warrenty when i bought the truck. Hopefully something like this will be covered if it gets worse. It also might be the gas maybe i guess. Any suggestions ? Thanks Jeff
Old Mar 26, 2005 | 08:11 PM
sprtsmn's Avatar
sprtsmn
What dealer did the oil changes?
Lifter noise would be a very fast ticking normally.
I'm nearby, so I'm curious !
Old Mar 26, 2005 | 08:21 PM
hdman6's Avatar
hdman6
Monroe ford in Monroe ny, The sound is a fast ticking sound but goes aways after a min or so of driving, like after it gets warm, jeff
Old Mar 26, 2005 | 08:27 PM
sprtsmn's Avatar
sprtsmn
Sounds like lifter noise.
I would have it checked ASAP!
Low miles, new truck.
Being a SOHC, you could eat a cam lobe or a lifter.
I'll be honest, often the oil used by dealers for "Free" oil changes is not the best. Perhaps do your own oil change and see if the noise goes away.
I'm in Wallkill, and bought my SD in Beacon. My first oil change was free at 1500 miles. I'm changing it again a 3000.
Oil's cheap, engine repairs are not.
Good luck!
Old Mar 26, 2005 | 08:41 PM
TGORM's Avatar
TGORM
Ticking
I had the same noise on a 99 f 150 5.4 and it was broken exhaust manifold bolts. It would stop leaking when it warmed up. Look at the studs and see of thers are any missing. If you lift the fender liner it is easy to see.
Old Mar 26, 2005 | 08:50 PM
99f350sd's Avatar
99f350sd
Exhaust is a possibility as is piston slap also lifter. Make sure to use motorcraft oil filter. Exhaust will get worse when you power up a hill when cold. Many will almost go away when warm. I had a cracked manifold that would almost be quiet when it got warm.
Old Mar 26, 2005 | 09:46 PM
bcnu2004's Avatar
bcnu2004
Take it back to your dealer ASAP. the more you drive it the more damage it can do. You may check your oil filter and make sure they put the right one on it with an anti-drain back valve. This sounds stupid but it works, take a sawn off broom handle and put one end on top of the valve covers and one end to your ear and see if you hear anything in the valve train. you can also do this on the oil pan to see if you hear a rod knocking. Hope your problem is nothing serious and your dealer takes care of you. Good Luck !!
