MPG decrease with Predator.
Old Mar 26, 2005 | 07:43 PM
bralos's Avatar
bralos
I have the Predator in my 03 Ford 6.0. I have only used it in economy tune. It ran great and MPH seemed to increase I was getting 18 MPG on average. This issue is when I went to the tow tune and then back to economy. I am now only getting 10 MPG.
I was running the economy and wanted to try the tow tune for a heavy load I had. I could not remember if I could go right from one tune to another or if I had to go back to stock and then load the new one. I decided to be safe and went from Economy to the stock then right to the tow tune. The truck ran fine anfter the tune. I then drove home and a few days later wanted to go back to economy. I was able to get on the net and did some reading and found out I can go right from one tune to another so I loaded right from Tow to economy. This is where the MPG has gone to crap. The truck seems runs fine otherwise.
Now the dilemma, I was thinking about flashing back to stock and then reload the economy tune. I need to contact support and get there input but was wonder if anyone out there has seen similar issues.
Jonathan
Old Mar 27, 2005 | 01:39 AM
argann's Avatar
argann
This may not help. I only tow in 100hp mode. Have you tried updating the software? They release new downloads every month or so. I haven't noticed any mileage decrease but I have only used 100hp mode.
...Rich
Old Mar 27, 2005 | 09:50 AM
bralos's Avatar
bralos
I updated the OS to the latest before I installed it. I also have been running the econ tune for 10 days hoping the transmission and engine just had to relearn.
You stated " I only tow in 100hp mode" What weight are you pulling? When I am towing I am pulling HEAVY! 15K LBS of hay at a time. I have the gauges and the pod but have not had enough time to install them. So I am hesitant to tow heavy in anything but the tow mode right now. I run the econ tune when I am not towing or towing light.
What temps are you seeing on the EGT? I assume you have the gauges due to towing in 100HP mode.
Jonathan
Old Mar 27, 2005 | 12:44 PM
argann's Avatar
argann
My travel 24ft loaded is about 12k maybe a little less. It is uphill from my house to the desert. I see 950-1k max post turbo. I would put the guages up asap. Whenever I see the trans or egt's get to hot I always back down a little. That extra insurance is priceless and the security to look and see exactly what is going on. I just went to stock and uplugged both batteries for an hour and drove it stock for a week. I didn't see any increase/decrease. Wanted to see with the intake/exhaust if that would make a difference.
I may order the SCT w/ Custom tunes next week. Depating.
...Rich
Old Mar 27, 2005 | 02:18 PM
ttsupra94's Avatar
ttsupra94
You aren't supposed to tow anything in the 100hp mode I thought, they warn not to do it at least. How long was it after you reinstalled the economy tune that you checked the mpg? I would give it a little while to readapt. I haven't had any problems. I'm getting about 17 with the economy tune.
Old Mar 27, 2005 | 03:45 PM
rtoy's Avatar
rtoy
You can tow in 100, but you need to watch the EGT all the time. If you don't the temp gets to over 1,200 real quick. I run mine at 65hp all the time and I didn't lose or gain MPG, and I have 30,000km on it now. My truck weight is 10,000LB. and I get 15mpg (canadian) combined hi-way/city.
