radiator size
Old Mar 26, 2005 | 04:32 PM
chris1937's Avatar
chris1937
radiator size
My 1966 has an 18 1/2 radiator. I would like to replace it. I noticed some of the 240's had the 23 3/4. What is the difference? How can I tell if the larger one will fit? Will it run cooler w/ the larger one? Is that better. I am adding performance parts this engine.
Old Mar 26, 2005 | 08:58 PM
chris1937's Avatar
chris1937
Question And The Water Pump
Is there anyone out there that can answer my radiator question? Also, where would I find a replacement water pump for my 66 240 I6?
Old Mar 26, 2005 | 10:12 PM
datchew's Avatar
datchew
hi Chris.
you might try posting in the 1961-1966 forum.
those guys might be familiar with the make of your truck and be able to help you more.
Old Mar 27, 2005 | 01:28 AM
Argo's Avatar
Argo
Originally Posted by datchew
hi Chris.
Generally, bigger is better for a radiator, just be sure to use the proper thermostat for the engine. Too much cooling capacity is better than too little, as the thermostat can regulate the temperature.
Old Apr 2, 2005 | 11:10 PM
ptmilan's Avatar
ptmilan
I have a 1966 240 and I got a waterpump at Autozone.
Old Apr 2, 2005 | 11:49 PM
Argo's Avatar
Argo
The 240 and the 300 should use the same water pump, since they use the same block.
