installing headers
Old Mar 26, 2005 | 03:30 PM
r0n1n's Avatar
r0n1n
installing headers
is installing headers something somebody with limited experience can do in a weekend? thanx
-jason
Old Mar 26, 2005 | 05:11 PM
Bouts21's Avatar
Bouts21
I put headers on my 78, took about a day I guess for both sides. But I messed around, started, stopped, you know!! Removed the clutch pivot rod on the drivers side, and the starter motor on the passenger side, headers bolted right up. Hedman Elites
Old Mar 27, 2005 | 10:23 AM
Scorpion_DvT's Avatar
Scorpion_DvT
Most definitly, if you start early enough, you should be able to get it done in a day, worst a part of the next. Tip: make sure you get new bolts, top notch gaskets, torque wrench, and make sure you clean your bolts holes with a small wire brush and get a can of compressed air to clean out any filings so you can get proper torque on each bolt...good luck man, you'll feel good after it's done.
