coolant question
Old Mar 26, 2005 | 02:06 PM
4x4man514's Avatar
4x4man514
coolant question
ive heard that i need ton use a special type of coolant in my deisel because of cavitation.is this true?if so ,what kind and where can i get it?thanks guys.
Old Mar 26, 2005 | 02:15 PM
Lazy K's Avatar
Lazy K
Yes you are correct you need to use an anti-cavitation fluid. The best I have found is made by Case for their tractors so you should be able to get it from any Case dealer. Just follow the instructions.
Old Mar 26, 2005 | 02:49 PM
tjc transport's Avatar
tjc transport
i ain't rite
you can also use a product be napa called napacool. 1 pint treats 4 gallons.
Old Mar 26, 2005 | 03:30 PM
4x4man514's Avatar
4x4man514
well its saturday and i dont think the case dealer is open and im in a hurry.
this napacool,is it an additive you put with regular antifreeze?
thanks ,Kevin.
Old Mar 26, 2005 | 04:48 PM
tjc transport
i ain't rite
yup, it is an anti cavitation addative that you pour in with the antifreeze.
Old Mar 26, 2005 | 05:33 PM
soulpatchfr's Avatar
soulpatchfr
napacool is a coolant additive along the likes of fleetgaurd (at ford/IH) or the case stuff. you're looking for SCA's or DCA's - Supplemental or Diesel Coolant Additives. they aid in fighting against cavitation, as noted.
you want a measured amount, so buy the test strips when you get the additive. add correct amount per mfr directions. the different brands may have different properties that don't mix well, so... well, so don't mix them.
some coolants also come pre-charged with SCA's, so that's an option.
i use low silicate green napa stuff & their napacool pre-charged coolant filters, myself.
Frank
Old Mar 26, 2005 | 08:58 PM
cemenacho's Avatar
cemenacho
Caterpillar has some great stuff too. It is pink and I'll tell you, it has some real good cleaning agents in it too
BigG'sBlueMonster
Dec 2, 2007 11:27 PM
trapperon
1997 - 2003 F150
Jun 28, 2005 11:33 AM
Mopey
Nov 2, 2004 09:09 PM
01' Super Crew
1997 - 2003 F150
Mar 6, 2003 09:26 PM
