Green Disease
Old Mar 26, 2005 | 10:06 AM
crazzeecannuk
Guest
Posts: n/a
Green Disease
I wish I had the knowledge before that I have now ... after exhausting all my mechanics and mechanic friends to correct a truck that would die at lights and on the hiway at 90km/hr my 87 F150 is now new from the tank to filters. Including all electical components (distributor, coil, wires, plugs, sensors etc ... to find that the main yellow feed wire from the harness to the solenoid was cracked and corroded (green disease) So go out and check your harnesses before you go through the trial and error procedure. I now have a new truck with only 137000 original kms. Crazzecannuk OUt.
Old Mar 26, 2005 | 12:05 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
