I have a 1999 2.5 liter and the alternator will not charge the battery. I have installed a new battery,Alternator, and Belt. Is there a regulator someplace or is it built in the alternator. The volt meter indicates that the alternator is producing 12.1 volts. I had it tested at a auto parts store and they claim it is producing over 14 volts. Any ideas what the problem could be?
...Welcome Craig, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
