5.4L Is missing after cleaning
Old Mar 25, 2005 | 11:08 PM
Calkidd's Avatar
Calkidd
Hello to all, this is my first post, but unfortunately it is under less than great circumstances.
I just had a Flowmaster Super 40 installed on the truck, so I was feeling good and decided to detail the engine. I sprayed a little degreaser, hosed it off and added a nice shinny dressing solution on it.
So I go to started it and now it has a consistent miss all the time. Whether it is in gear, out of gear, driving or idling, it always has a miss.
What would be the best thing to do? If I use a code reader will it tell me what cylinder is missing? How probable is it that a COP fried?
Thanks in advance for your information and patients.
Old Mar 26, 2005 | 02:26 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
A normal scanner will tell you which cylinder is misfiring only if the misfire sets a code. You might have to drive it quite a while before it will do that.
Most likely you just have water in one of the spark plug holes and that's shorting out the plug or COP. It's some work but if you remove all the COPs and dry them and their holes you'll probably cure the miss.
How many miles on your truck? If it's anywhere close to being due for new spark plugs now might be a good time.
Old Mar 26, 2005 | 10:13 AM
mrung0wa's Avatar
mrung0wa
Howdy
I got an 03 EXP w/5.4 and I want FLOWMASTERS!
Despite the spark/firing problem how do you like the 40's!
Old Mar 26, 2005 | 12:48 PM
LxMan1's Avatar
LxMan1
I have a 40 series on my 01 F150 and I love it. Not overly loud, but it has a nice rumble to it
Old Mar 26, 2005 | 07:20 PM
Calkidd's Avatar
Calkidd
I was worried about using the 40 series but I was told it is what he installs on the majority of the Fords. The 40 sounds very nice and has little resonance inside the cab.
Well, I am thinking the water theory is where the problem lies. Today, the missing had subsided, but came back after a restart.
When the missing comes back it isn't as bad as before. It is more noticeable upon an easy acceleration from a stop.
I am very mechanically incline, but what shop manual would be the best?
Old Mar 26, 2005 | 07:21 PM
Calkidd's Avatar
Calkidd
I am assuming if the "Engine Service Soon" light is on, then a code has been thrown.
Old Mar 26, 2005 | 07:32 PM
Racerguy's Avatar
Racerguy
Yup that's right.
Has your light been on?
Old Mar 26, 2005 | 09:32 PM
Calkidd's Avatar
Calkidd
Yup that's right.
Yes, and it stays on, which leads me to my next question. How do you reset it?
Old Mar 26, 2005 | 09:46 PM
Racerguy's Avatar
Racerguy
Before you reset it you should take the truck and get it scanned to see what code you have so you can figure out what caused the light to come on. Some parts stores will do that for free. The code can also be cleared to turn out the light with the scan tool.
Or you can just disconnect the battery for a few minutes and that will clear it too.
Old Mar 26, 2005 | 10:31 PM
Calkidd's Avatar
Calkidd
Thanks for everyones help. I reset the computer after realizing I should have waited and found out what the code was.
Now, just because I reset the light, that doesn't mean the code will be gone. Doesn't it store the code in the computer?
Old Mar 27, 2005 | 11:36 AM
Racerguy's Avatar
Racerguy
It stores the code....until you reset it.
Old Mar 27, 2005 | 04:42 PM
Calkidd's Avatar
Calkidd
Perfect, I will invest in a code reader.
One more question, what is a good, economical code reader?
Old Mar 28, 2005 | 03:48 PM
Calkidd's Avatar
Calkidd
Well, since the start of this post, the truck has now stopped missfiring. I was told if I were to clean the engine again use WD-40 to displace the water under the COP.
I don't want this problem to ocurr again, but I don't want a dirty engine. What does everyone else do to clean their engine?
Old Mar 28, 2005 | 07:51 PM
mrung0wa's Avatar
mrung0wa
Ahhh!
Good old Water Displacement attempt Number 40.
Made by good ole folks in San Diego, California who know what good penetrating oil should smell like!
Works great on masking those pesky foul odor's too!
Lman
Mr. Mcbeevee
Escape & Escape Hybrid
Jan 5, 2013 10:05 PM
matthews_56
Bronco II
Jun 18, 2003 06:59 PM
pappasplace
Apr 10, 2003 08:26 PM
sloth71
Dec 3, 2002 05:38 PM
