dizzy question!
Old Mar 25, 2005 | 10:21 PM
Bulldawg1081's Avatar
Bulldawg1081
dizzy question!
im changing the points in my car to electronic ignition and have a distributor for a later model 302 like mid 1980's but when i took the points distributor out of my car today the little gear and shaft on the points distributor was alot smaller than the later model 302 electronic distributor...what years did it change? will a dizzy out of a 351 windsor work?
Old Mar 26, 2005 | 12:13 AM
mako5972's Avatar
mako5972
A dizzy out of a 351W won't work, it will be too tall.
Old Mar 26, 2005 | 12:41 AM
Bulldawg1081
just exactly what i was afraid of....why is the later model dizzy gear alot bigger than the points style if they are both for a 302?
Old Mar 26, 2005 | 01:06 AM
mako5972's Avatar
mako5972
Did you try switching the gears?
Old Mar 26, 2005 | 01:49 AM
Bulldawg1081
yeah but the shaft is alot smaller...
Old Mar 26, 2005 | 06:49 AM
baddad457's Avatar
baddad457
Just use the dist you now have. Install a Pertronix unit in it, add a hotter coil, new wires and plugs and you'll be done with it. Only two wires to hook up ( to the coil) takes thirty minutes tops for the whole install.
Old Mar 26, 2005 | 06:08 PM
mako5972's Avatar
mako5972
Like Baddad said, a Pertronix unit will work real nice. Then you still can maintain the original stock look.
Old Mar 26, 2005 | 10:48 PM
Bulldawg1081
hey i appreciate it,i think ill do what your saying until i can save the money to get the distributor that looks like the chevy HEI..
Old Mar 27, 2005 | 12:50 AM
baddad457's Avatar
baddad457
Once you install the Pertronix unit, you'll forget all about that HEI distributor.
