D0VE head compression
Ryan
This is why the aftermarket provides dished and below deck pistons to get the C/R down below 10 to 1 or the cranking PSI in the 165 to 175 PSI window.
On the flip side a bone stock mid 70's to mid 80's 460 with its 27 cc dished pistons, .025" below deck and D3 cylinder heads cranked at about 125 to 145 PSI with a stock cam and pathetic 7.8 to 1 actual C/R.
Keep in mind that there is not a direct corrolation between C/R and cranking PSI unless the cam specs remain the same. Change (increase) the cam duration and more importantly (delay) the intake valve closing point and the cranking psi will fall for a given static C/R...
In order to run on todays pump premium you must keep cranking PSI below 200 to 210 with aluminum heads regardless of cam choice and 180 to 190 with iron heads regardless of cam choice. More cam needs more static C/R to achieve these targets.
SMJ/RHP
http://reincarnation-automotive.com
