86 rear brakes
Old Mar 13, 2001 | 08:24 PM
nap's Avatar
nap
86 rear brakes
does anyone out there know why my rear brakes won't lock up or even stop my rear wheels when jacked up. brakes new,cylinders new.ajusted right. can slow wheels but can't stop them no matter how hard i press.
Old Mar 14, 2001 | 12:52 AM
knuckles's Avatar
knuckles
86 rear brakes
Were the brake shoes installed correctly (primary shoe on the towards the front)???
Old Mar 14, 2001 | 04:52 PM
otto's Avatar
otto
86 rear brakes
could be the weight adjuster which almost cuts the back breaks off when unloaded and engages them more when loaded, i dont think any F-150's had this but i know my friends 85 F-250 did and it screwed up sometimes
Old Mar 14, 2001 | 05:53 PM
fatforty's Avatar
fatforty
86 rear brakes
Hi, is all the air out of the wheel cylinders????? John
Old Mar 14, 2001 | 10:56 PM
Franklin2's Avatar
Franklin2
86 rear brakes
otto: Is this the valve looking thing mounted on the rear axle housing? We had a company pickup with a valve looking gizzmo that the rear brake lines went to and it had a rod/plunger setup that looked like it worked when the axle housing twisted. Does the axle twist more or less depending on the load in the truck and compensate the rear brake pressure? This was a wild guess when I was under there looking at it.
Old Mar 15, 2001 | 07:54 PM
otto's Avatar
otto
86 rear brakes
Yea thats the valve but i dont think the axle housing twist it just recognizes the the springs are compressed (frame towards axle) and it will apply more pressure to the rear brakes, the arm and whole assembly is goofy looking but thats what it is <weight adjuster> lol
Old Mar 15, 2001 | 08:00 PM
redstone's Avatar
redstone
86 rear brakes
