I know there's a few of you Fordomatic stockers out there...you'll know this.
When I got my truck a few weeks back one of the small problems was that it won't start in park. This is easy so I begin a search for a stock neutral safety switch replacement.I was told by Bob's F100 that they would send the wiring info with the switch.
Anyway, new switch arrives, looks the same as old one except slight configuration change on the terminals. Bob's didn't send the info on the wiring so they are now looking into it.
Here's the question...both switches have four terminals but I've only got two wires located at the switch. The wiring info isn't available from Ron Francis or the stock diagram as far as I can tell.
Can someone look at their stock setup and tell me how to wire this thing in correctly?
I'll have to go out and look at mine(60), As to my knowledge, mine had no provision's in the harness for hooking it up, as mine was non-functional, I'll take a look at my sitch though. -4speed
