2" or 2.5" spacers? which ones
I like it mo betta
Aloha all, I just installed the Autospring 2" in my 04 scab Lariat. They are a very well made all steel unit. In my opinion the 2" is perfect and I didn" want any plastic spacers in that heavy compression position. Word of caution::: If you dont have all the tools and expertise, have someone that does do it for you!!! I bought the parts direct from Autospring and quized them on the alignment after installation. Answer was, no alignment needed only toe in needs to be set. This turned out to be true and my toe in was way off. After I set it everything seems to be fine. The spacers raised the front bumper 3 1/4". Looks much better and rides the same with a little more clearance. $129.99 delivered in 5 days to Hawaii. I like it!!! Thats all folks. Larry in Kona
I just installed an autospring 2" kit. The installation was quick and easy and the ride is unchanged except that there is no more bottom-feeding. I think autospring is a little pessimistic about their lift heights. The 1 5/8" spacer that they say lifts 2" actually gave me almost 3" after adjusting the toe in. If you choose the 2.5 you'll probably want to lift the rear as well. Good luck.
Wetdog
Wetdog
Sorry for digging up an old thread but I thought this would be a good place to ask this question. I'm looking at installing a 2" Autospring level kit on my 2004 F-150 4x4 Screw Lariat, but at work I have to park in a 6'8" clearance parking garage, and it barely fits as is. How much total height was changed on the truck after the 2" level kit was installed and toe aligned? Thanks.
slowmans
1999 to 2016 Super Duty
12-16-2011 11:42 PM
2004FX4Wheeler
2004 - 2008 F150
31
03-29-2004 03:15 PM
