Engine dying at operating temp..
Old Apr 29, 2005 | 02:21 PM
drewcoolness99's Avatar
drewcoolness99
mustang where was yours shorting at? I check the harness and everything looks fine.
Old Apr 29, 2005 | 02:52 PM
MemOrex's Avatar
MemOrex
Unplug the O2 sensor harness and see if it stays running.
Old Apr 29, 2005 | 06:08 PM
wtroger's Avatar
wtroger
jump fp test lead to ground and turn on ignition switch you should here the pump run. Then start the turck and see if it stays running if it does then you have a computer problem shutting down the fp. I have an 89 mustang that we run this way all time becuse the fp won't run from the computer. if it still does it then look at the fp relay and the crash switch.
jpgrove
Dec 4, 2015 08:48 AM
jdj0716
Aug 5, 2010 10:50 PM
mastaplan2k8
Mar 15, 2009 08:40 PM
77300i6
1983 - 2012 Ranger & B-Series
20
Oct 22, 2008 06:55 PM
bobsuisun
Mar 15, 2006 05:11 PM
