MESSAGE TO PAUL
Old Mar 19, 2001 | 07:18 PM
jams3's Avatar
jams3
MESSAGE TO PAUL
PAUL YOU ASKED ME THE OTHER DAY IF I HAD A MASS AIR SCENCER
IN MY TRUCK 94 F150 5.0 THAT IS PINGING.
I CKED THE EGR AND IT WAS FINE.
WAS HOPING YOU WOULD RESPOND SONNER
I WAS GONA CK THE NOCK SCENCER TILL U ASKED THIS QUISTION
PLEASE LET ME NO WHAT TO CK AS I DO HAVE A MASS AIR SCENCER.
THANKS
MARC
Old Mar 19, 2001 | 11:25 PM
PAUL_2's Avatar
PAUL_2
MESSAGE TO PAUL
If I dont get back to a post within a day or so use the message function to remind me . A Mass Air Flow sensor , If your truck has it , I cant recall right off when they were first used on the F150's is located on the air intake hose , it will be mounted directly after the air filter housing . They have wires that over time accumulate dirt & reduce their function which in turn can cause the pinging you describe . It is possible to clean them using an electrical part spray cleaner but be careful with them because if you break them you have purchased a new sensor . First verify that your truck has Mass Air Flow Sensor .
Old Mar 19, 2001 | 11:48 PM
jams3's Avatar
jams3
MESSAGE TO PAUL
THANKS FOR REPLYING PAUL
YES IT HAS A MASS AIR SCENCER
THE WIRES U ARE REFERING TO ARE THEY AT THE PLUG?
ITS LOCATED ON THE INTAKE PLUMBING NEXT TO THE AIR BOX
SOMTHING NEW TO ADD TO MY DELIMA WHEN I DROVE IT TODAY
THE TEMP OUT SIDE WAS 91 AND I WAS ON THE FWY DOING 60
OR SO I GAVE IT A LITTLE GAS AND IT PINGED. I HAD THE AIR C0N
ON THE GROUND WAS FLAT AND MOTOR TEMP WAS NORMAL.
IF U LOOK AT MY FRIST POST ON THIS PROBLEM YOU WILL SEE
WHAT I HAVE DONE SO FARE AND THE CONDISHIONS THE TRUCK
WAS RUNNING UNDER.
ITS TICKEN ME OFF
THANKS
MARC
Old Mar 20, 2001 | 06:22 AM
DannyP's Avatar
DannyP
MESSAGE TO PAUL
Old Mar 20, 2001 | 11:12 AM
PAUL_2's Avatar
PAUL_2
MESSAGE TO PAUL
Marc , I understand you want your truck running correctly , but you dont have to post using all capital letters , it just makes it hard to read .
Remove the Maf from the air intake hose , once its removed you should see two thin wires , Use the Electrical Contact Cleaner Spray to clean them . Reinstall it & see how it runs .
oldies
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 8, 2014 12:48 PM
litespeedvortex
6.4L Power Stroke Diesel
Feb 16, 2009 09:26 AM
user 48373737373
1947 and Older Ford Trucks
Apr 26, 2003 12:42 AM
boss3024me
May 9, 2001 10:56 AM
