Sponsored by: Kumho
running 36's ???????
Old Mar 23, 2005 | 06:59 PM
78 Ranger's Avatar
78 Ranger
is there enough clearence on a stock hiboy to run 36's and what gears would u recommend
Old Mar 23, 2005 | 08:40 PM
77300i6's Avatar
77300i6
Well, 35's will fit, but I think that with minor trimming(like cut out flares) 36's may fit too. As for gears, it depends on what you're doing with your truck and how much power your engine makes. Obviously if you have adequate power you really don't need really low gears(torque multiplication) to get things moving. This would also help your highway cruising RPM's. I would say at least 4.10's and 4.56's would give you more pulling power.
Seeing that you have a hi-boy, I would say you have 4.10's already? If you don't know what gears you have you can post the axle code here and someone will decode it for you.
