Code Po153
Old Mar 23, 2005 | 12:07 PM
949803's Avatar
949803
Code Po153
I had a check engine light come on. The dealer advises the code it shows as PO153 and that both "HEGO" sensors have slow responce." Can anyone tell me what the "HEGO" sensors are; and where they are located? I have the Chiltons, but cannot find "HEGO: anywhere. Thank You !
1998 Explorer 4.0 SOHC
Old Mar 23, 2005 | 12:38 PM
fefarms's Avatar
fefarms
HEGO =
Heated exhaust gas oxygen sensors. AKA oxygen sensors. AKA 4 wire oxygen sensors.
They are mounted in the exhaust system ahead of the catalytic converter.
P0153 is specific to bank 2 sensor 1. You cannot say that both sensors are slow from seeing just code P0153, though the dealer could have hooked up a tester and looked at the cross counts for both sensors. Perhaps they are both slow, but only bank 2 is over the P0153 limit.
If the Oxygen sensors have more than 75000 miles on them, I would change them both out. They cost about $50 each. If the oxygen sensors are nearly new, I would try to figure out which bank is "bank 2". One way to do this is to deliberately disconnect the harness to one of the sensors. That will post a fault code other than P0153, but similarly specific to one bank. From this you can determine which bank is which.
www.troublecodes.net, under the OBD2 section, has the list of fault codes.
Old Mar 23, 2005 | 01:07 PM
949803's Avatar
949803
Code PO153
Thank You FeFarm. I appreciate the help! I am 75+thousand miles and will replace. Thank You WDM
Old Mar 24, 2005 | 09:06 AM
thelonerangerxlt's Avatar
thelonerangerxlt
Bank 2 is the driver's side on the 4.0. Sensor 1 is the upstream one, which is the one closest to the exhaust manifold. (I believe there's only one on this side.)
dunnc1989
Mar 6, 2011 07:10 PM
joestratton1
May 25, 2008 11:11 PM
kiohio1985
Nov 6, 2007 12:00 PM
Skandocious
18
Jul 8, 2007 04:46 PM
