I will be installing compressed air lines in my basement and attached garage. It seems that most do this in copper tubing. I am planning to use galvanized pipe.
I would appreciate any recommendations or comments from anyone with experience in this area.
Galvanized or 'black' pipe. I am leary of using thin-wall copper for (relatively high) pressures.
Be sure to put a dryer in the line, and (I think they're called) 'drop' lines to allow moisture to be drained from the lines, below the quick disconnect(s).
I saw a new system using aluminum tubing and connectors on 'Two Guys Garage' a while back. Not sure of the cost, but, you might consider that.
I have never seen thinwall copper used for Air. I agree with 00BlueOvalRanger.
Black pipe is the way to go. But that is easy for me to say since I have all the tools to cut and thread it. With out those, it can be a real pain.
I saw those aluminum kits at Home Depot awhile back on the closeout sale rack. It was kind of expensive as I remember, but might be easier to work with.
I took out my PVC and switched to copper a while back and am pleased with it. Much easier installation than cutting and threading iron pipe to the desired length. I don't know if it is true but I read somewhere that some galv. pipe had a tendancy to flake off and clog paint nozzles and that particular site recommended black pipe, again I'm not sure if that is true. They also said to use pipe dope instead of teflon tape for the same reason.
Copper is rated and labeled by type. Hospitals use copper for pressurized gasses all the time, if you search on the net, I forget wether it is type L or M that they recommend and brazing the lines. Although one thing I saw said use silver solder (don't know I trust solder). As for the nice looking aluminum system, unless it's REALLLLLLY come down, you could probably pipe a house for water, gas, And air compressor first.
I believe the call for threaded fittings or silver solder for air lines is an industrial fire safety item. A sweated copper air line would come apart at the joints in a fire then feeding compressed air into the fire from a remote compressor location. I don't believe this is a concern for a home shop system as any fire would also involve the compressor location. Also most home systems don't have sufficient air to be a long term fire concern.
Silver Solder, isn't that just a sweated copper line, just a different solder? Or is it in the brazing section somewhere?
Not to mention the temperature-pressure increase would likely blow the safety valves before the joints failed... but there are so many other variables...
The company I work for designs/installs copper compressed gas systems all the time - brazed Type K for clean air systems.. When the time comes to install the air piping (need finished walls first) I'll probably go with copper. If for no other reason than to practice sweating joints...
There are some good recent threads here on copper pipe with references to service pressure and solder types. Copper is probably the best pipe to use all around. Even the thin wall "M" type is good enough to use with the lead free solders we use. The older lead type solder produced a joint that was not as good for compressed air use.
You might want to go to a plumbing supply store for your fittings and tube rather than the home box store. I have seen some rather disturbing product quality in those places.
I have used galvanized iron in the past and have had no "flake" problems. I would think that anyone painting would use a filter before a paint gun anyway.
Check out my gallery for a point of use lubricator. DO NOT use a central lubricator on your compressed air system.
While you are checking for old threads check the archives, there is some great info there also on shop air systems.
There's a glue for copper joints if you don't want to sweat fittings. Haven't tried it,
but it is supposed to be better than solder. Maybe not silver solder. Looks easy to use
wonder about cleanup.
I was told that for commercial applications, only black pipe is acceptable; having said that, most places I have worked use copper, and I have used both copper and PVC without problems. A lot would depend on if you have regulated air pressure, such as 100 psi in your lines, or unregulated, which would be 175 psi in the case of my compressor. Metal lines of any kind will help water condense out faster. Be sure to slope your horizontal runs, and put drain points at the ends.
in a foam injection molding plant i worked at in florida, we used copper comming off of all three compressors. i dont remember the hp of the compressors, but they were about 15 by 10 by 10 tall, and the copper held up fine and is still there. the copper fed into a header, and then into a huge tank. from there it was welded black pipe.
Sweating involves the use of copper and a propane torch, while brazing requires more heat and the use of brazing rods available from NAPA and welding supply houses. Be sure to clean the inside of the joints as well as the ends of the copper tubing to remove the shellac finish they use to keep them from discoloring.
