removing exhaust resonator...
Old Mar 23, 2005 | 06:29 AM
kemerick's Avatar
kemerick
Would it be okay for the truck (2004 PSD) to remove the exhaust resonator? I have had the muffler replaced with a straightpipe for about 6 months and it sounds much better but it is too quiet.
Will it be too loud by removing the resonator? Is there any downside to doing it? Is there any HP gained?
Old Mar 23, 2005 | 10:18 AM
psmith338's Avatar
psmith338
Your question "will it be too loud?" is subjective. It depends on an individual opinion.
In my opinion, "yes", but I like a low "authoritative" rumble similar to stock Mustang exhaust, etc.
Old Mar 23, 2005 | 11:49 AM
sriddle's Avatar
sriddle
The resonator is supposed to get rid of the annoying whistle. The later models have software changes to the variable vanes in the turbo to minimize this and thus the resonator is not on my 05.
Old Mar 23, 2005 | 05:52 PM
PAN's Avatar
PAN
removing the kitty kat will make it alot louder than just changing the downpipe
Old Mar 25, 2005 | 09:13 AM
kemerick's Avatar
kemerick
Does the 2004 PSD have a catalitic converter? I have never looked as I assumed it would not being a diesel.
I have read that it is "okay" to remove the cat... but is there any downside to removing the cat... any at all?
I want to make the truck louder and have contemplated removeing the resonator, at least thats what I think it is. Then again I have read here that removeing the cat may do the trick for me.
Old Mar 25, 2005 | 10:19 AM
fordfast's Avatar
fordfast
I gutted my cat and put on MBRP exh, sounds awsome!!
Old Mar 25, 2005 | 06:02 PM
kemerick's Avatar
kemerick
What do you mean by you gutted your cat? Did you remove the contents and replace with a straight pipe?
Old Mar 26, 2005 | 01:22 AM
veselyc's Avatar
veselyc
i removed the stock exhaust on my 04' and went w/ a 4" stainless kit from magnaflow. exhaust noise is noticable @ 75mph and above. you get use to it.
Old Mar 26, 2005 | 07:49 AM
fordfast's Avatar
fordfast
Gutting cat- take air chisel or other weapon and remove contents then bolt back on.
Old Mar 27, 2005 | 10:55 AM
PAN's Avatar
PAN
If it were me I would un-bolt all your factory exhaust and replace it with a system. That way if you ever majorly tear your truck up, you can put the stock converter and downpipe back on and there won't be any warranty issues when you take it in.
deucerx11
Jun 16, 2017 08:15 AM
Pastor Scott
Nov 17, 2016 05:28 PM
ginomachino
6.4L Power Stroke Diesel
Aug 28, 2016 07:01 PM
Hedgehog1
6.2L V8
30
Jan 22, 2016 03:06 PM
Bigred1995
Apr 14, 2015 09:09 PM
