4.6 engine swap
Old Mar 23, 2005 | 01:08 AM
old uhaul's Avatar
old uhaul
4.6 engine swap
has anyone swapped
in a modular 4.6 into a early truck?
i saw a 1997 crown victoria with a 4.6 v8 and automatic with 50k miles.
it is hit in the rear and should sell pretty cheap.
i am not new to engine swaps but was wondering if they are tough to wire,does anyone make an aftermarket wiring harness for this engine?and are there anti theft issues to deal with?
also not sure if this is attached to an overdrive trans or just a 3 speed.
Old Mar 24, 2005 | 10:42 AM
William's Avatar
William
I wish someone would respond. I am considering a 4.6 or 5.4 mod motor swap into a 66 F100. I know wiring harnesses are available for a 5.0 swap. Transmission controlers are available for the aoe transmissions. I'd like to see info on motor mounts as well. The Junk Yards are full of these engines and surley someone has done this swap before.
Old Mar 24, 2005 | 09:06 PM
Greg R's Avatar
Greg R
If you want to do a mod motor swap you have to check out www.modularfords.com . You can find just about anything you need to know there.
Greg
Old Mar 25, 2005 | 07:39 AM
William's Avatar
William
Thanks Greg! That site rocks!
Old Nov 23, 2020 | 08:34 PM
Byron Burnett's Avatar
Byron Burnett
I'm moving a 1997 F150 4.6 to a 1964 f100. The wiring harness was damaged in the extraction of the engine. Let me tell ya, replacing that harness today is a nightmare and the security function is another pain in the tailgate.
Old Nov 23, 2020 | 08:37 PM
Byron Burnett
if you are still out there , I'm moving a 1997 F150 4.6 to a 1964 f100.
