dual shock brackets
Old Mar 22, 2005 | 09:38 PM
fords_forlife's Avatar
fords_forlife
dual shock brackets
hey, I was thinking it would be cool to put dual shocks on the front of my truck '83 F-150 4x4 and was wondering what I would all need to do this. Do I have to get the bracket off a doner vehical or are there other sources. Was this just an option or what determines if a truck got dual shocks and is there anything else I would need to do the conversion.
FORDS_FORLIFE
Old Mar 22, 2005 | 10:23 PM
bremen242's Avatar
bremen242
FORDS_FORLIFE
you could grab the mounts off of a bronco- to me, it seems like a lot more broncos have dual shocks.
or, you could merely weld a couple mounts onto the current setup
Old Apr 1, 2005 | 05:06 AM
Steve_Uzi's Avatar
Steve_Uzi
Yes getting the parts from a Donor Bronco is the way to go. All 4 of the 80-86 Bronco's I have owned - Still currently own 2 of them - have had Quad Shocks.
Everything should bolt right up. The holes should even be in the frame to accept the Different Coil spring bucket.
