Sponsored by: Auxito
hesitation when accelerating
Old Mar 22, 2005 | 07:07 PM
svrider2001's Avatar
svrider2001
ive have been fighting this problem for a week. its a 97 f150 4wd 4.6l. it started with water in my fuel tank. i replace the fuel filter,plugs, run some trectron injector cleaner, clean my maf, changed pcv valve. i unplug the injectors one at a time they all seem to be working. what its doing now is if i push the accelerator to the floor it really shakes. if i let up on the accelerator it smooths out. can anyone give me some ideas.
Old Mar 23, 2005 | 12:18 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
Did it run the same before you replaced your spark plugs?
I wouldn't be surprised if you had a bad plug wire causing your problem.
You may want to replace the set.
