Starters
Old Mar 30, 2001 | 02:31 PM
cgl's Avatar
cgl
Starters
Old Mar 30, 2001 | 11:40 PM
rollpan's Avatar
rollpan
Starters
[font size="1" color="#FF0000"]LAST EDITED ON 31-Mar-01 AT 00:44 AM (EST)[/font][p]I put a 89 5.0 from a mustang gt in a 85 f150 that had a 300 six cyl in it. the six had a clark four speed overdrive. The bellhousing with the clark is for a 164 tooth flywheel, the 5.0 has a 157 tooth flywheel on it, is there a starter that will make up the miss match or will I have to change the flywheel? (I bought the flywheel new -ford motor sport)
Old Mar 31, 2001 | 05:44 PM
hemi's Avatar
hemi
Starters
if the 157 tooth wheel is for a 5.0, then use the 5.0 starter.
Old Mar 31, 2001 | 08:37 PM
rollpan's Avatar
rollpan
Starters
The starters are the same for the 300 and the 5.0,the bellhousing is different.
Old Apr 1, 2001 | 12:09 PM
hemi's Avatar
hemi
Starters
can the pinion gear be changed on the starter?
