Correct MAF conversion?
Old Mar 22, 2005 | 02:35 PM
PyroBob's Avatar
PyroBob
I have a 1994 f-150 5.8L.
I wanted to do a MAF conversion, but ford didn't have a kit that would work. However, it seems that the lightning kit would, and I do have an E40D tranny.
Am I mistaken, or is this the right kit for the job?
ford part #: M-6066-T51
If this is the right part, then would it be safe to assume other 93-95 lightning engine parts are also compatible?
Old Mar 22, 2005 | 06:30 PM
EPNCSU2006's Avatar
EPNCSU2006
The kit would work, but you would need to modify the air tubing between the MAF meter and the dual throttle body. The lightning 351 is just a hot rodded version of the regular 351, so several parts will interchange.
Old Mar 22, 2005 | 10:22 PM
PyroBob's Avatar
PyroBob
Going out on a limb here, but with forged parts and better heads/cam, would a ford racing blower kit for a lightning work?
Old Mar 22, 2005 | 11:06 PM
EPNCSU2006's Avatar
EPNCSU2006
You'll again run into the two intake hoses as opposed to the single bore throttle body found on the lightning motor. It has a GT-40 intake manifold. I'm sure the supercharger would work, but I don't know what kind of gains you would see, or what dangers you would run into on a regular 351.
