Missing
Old Mar 29, 2001 | 04:27 PM
trh24's Avatar
trh24
Missing
I left a post yesterday about this truck. Truck has a 460 fuel injected/ 5 speed. I have now changed the cap and rotor, fuel filter, plugs wire and fuel pressure regulator and it still idles very rough, almost to the point of stalling when push the clutch in and hold the brake and there is still a horrible miss. Any help would be appreciated
Old Mar 29, 2001 | 09:49 PM
hotrodford_88's Avatar
hotrodford_88
Missing
Is there any chance one of the wires may be crossed? Also check to make sure the plug wires are completely seated on the plugs and cap.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old Mar 30, 2001 | 12:27 AM
trh24's Avatar
trh24
Missing
The wires are all tight on cap and plug. And i checked to see that none of the wires are crossed. So i really don't no what to do next. thanks for the suggestion
Old Mar 30, 2001 | 12:49 AM
hotrodford_88
Missing
Are any of your wires that fire in sequence touching each other? I don't know if that makes any sense or not, but I have heard of that being a problem on some of the engines.
Did it miss before the tuneup? Have you checked the coil or the ignition module? That is the only other thing I can think of at the moment.
Can see both below.
Old Mar 30, 2001 | 06:10 AM
trh24's Avatar
trh24
Missing
Here is my original post, put the truck was missing before the tune up and i found i had a couple of dead wires.
"I was wondering if anyone had any clue what happened today....The truck was running fine, got to where I was going, ahut the truck off for about 10 minutes. When i went to leave, it started fine, ran good for a few minutes. Then i got out on the highway and the truck started to bog down/starve for fuel. There was plenty of fuel in the tank but i switched to the rear tank and that seemed to solve the problem. Temporarily. Now the truck idles really rough, missing bad at idle, slight miss on the road. I changed the cap and rotor(rotor and cap carbon tracked bad) also i changed the fuel filter. None of these seemed to change anything....
Any Suggestions? "
Old Mar 30, 2001 | 07:14 AM
slikness's Avatar
slikness
Missing
Your original post talked about fuel starvation and I would concentrate on that area. Is your fuel pressure constant? You might want your in-tank fuel pumps tested. Are you sure you didn't get a tank of bad gas. Is it cold where you would experience icing in the fuel lines because of excess water in the gas?
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Mar 30, 2001 | 07:15 AM
slikness's Avatar
slikness
Missing
Also, are your injectors firing? Are they clogged and need cleaning?
Slik
Old Mar 30, 2001 | 07:15 PM
trh24's Avatar
trh24
Missing
The pumps are 5 months old, But i will try to test them. Any ideas how to test the pumps and also the injectors.
Old Mar 31, 2001 | 08:03 AM
46cabover's Avatar
46cabover
Missing
Pull the spark plugs to check injectors. The cylinder with the bad injector(s) will have a clean spark plug, while the cylinders with good injectors will be gassy. This is due to the ECM richening up the mixture to balance the fuel ratio. Why don't you try changing the filter first?
Old Mar 31, 2001 | 09:37 AM
walterdanek's Avatar
walterdanek
Missing
I hate to be the one to mention it, but how old is the catalyic convertor? Wonder if it is going bad on you. When the engine is hot, look under to see if the cat is cherry red. Had this happen to a friend who described something similar as you did. He too was looking at the fuel system, but his cat was bad.
Walter
Old Mar 31, 2001 | 10:05 AM
trh24's Avatar
trh24
Missing
Have changed the fuel filter already, butr i'll pull the plugs today and check them out. As far as the cat being bad, i checked it and it is fine.
Old Apr 1, 2001 | 11:12 AM
trh24's Avatar
trh24
Missing
This truck is still not running. I put a timing chain in it, didn't really need one but the boss said to do it. The truck was no better after the change on friday and now it barely wants to start without holding the gas pedal to the floor (its injected)
Old Apr 1, 2001 | 01:01 PM
hotrodford_88
Missing
I hate to ask this question, but could the timing chain be off one tooth? It could be a timing problem as well.
Can see both below.
Old Apr 1, 2001 | 06:00 PM
pickupman's Avatar
pickupman
Missing
About a year ago my uncle's truck was doing the same thing, it is an 88 with a 302 5 speed. He told me that he changed the distributor and that is was the problem. I don't know why and I don't think he did either, but that fixed it. I don't really like changing parts without a reason or without knowing that they are bad, I never did figure that one out though.
Old Apr 1, 2001 | 06:52 PM
trh24's Avatar
trh24
Missing
Hey thank you for all your help. But i have since gotten to the root of one of the problems. I pulled the valve cover off to make sure number one was up, and low and behold, I managed to shatter a valve spring into three pieces. Can't find the keeper and I think I shattered the piston.
