Pinion seal leak
Old Mar 22, 2005 | 11:05 AM
Zerojunk's Avatar
Zerojunk
Pinion seal leak
My 81 F-150 sat in the shop for few days and there is a puddle of grease which came by the pinion seal.Should I rush out and replace the seal or could the dealer have overfilled it when I had the grease changed?
Old Mar 22, 2005 | 11:14 AM
GreenSubmarine's Avatar
GreenSubmarine
If you are certain that it leaked from the pinion seal, I would change it. Mostly because, overfilled or not, it's supposed to be sealed. Anywhere gear oil can get out, water can get in - besides seals are cheap. Before changing it out, though I would check to make sure the leak did not occur somewhere else.
Good Luck,
Ernie
