blower motor
Old Mar 21, 2005 | 02:26 PM
dino360's Avatar
dino360
Cool blower motor
My blower motor is not blowing in any setting or speed. I am not sure if it is the motor itself or the switch. I used a couple of alligator clips to run direct power to the two wires on the blower plug and nothing happened. Did I test the blower correctly?
Old Mar 25, 2005 | 10:17 PM
Ultramagdan's Avatar
Ultramagdan
That should have spun the motor if it was good.
Old Mar 26, 2005 | 06:42 AM
blackf3504dr's Avatar
blackf3504dr
dino360 , I've just gone through this with my truck . I pulled the blower motor out and tested it on the bench and it would work , but wouldn't work while in the truck , the shaft was pitted . Did you make sure there is current to the motor ? if there is then you know the problem is the motor . I replaced mine ( $ 40 at Advance Auto Parts ) and it took care of it .
Old Mar 28, 2005 | 10:06 PM
dino360's Avatar
dino360
Cool
I also replaced mine. It was about 40 bucks.
