True Dual!!!
Old Mar 21, 2005 | 11:24 AM
1993_f150's Avatar
1993_f150
True Dual!!!
What is the cheapest way to true dual my truck. I believe i will have to by a set of headers for my truck and then put 2 high flow cats on after that and then have my exhaust comeout from that. Is that what i have to do. If so it sounds a
little pricy. If anyone has any suggestions, I'm all ears. Thanks for all the help
1993 F-150 4x4
Old Mar 21, 2005 | 03:10 PM
MemOrex's Avatar
MemOrex
$200-400 for headers. $100 for hi-flow cats. Add muffler costs, pipes, and labor.
Old Mar 21, 2005 | 03:43 PM
soccerlawn's Avatar
soccerlawn
I have duals from mainfold (hopefully have headers on there one day) into 2 40's flowmasters, and then out the back through 3.5" tips. I just scrapped the cats.
Overall it cost 200=pipe and labor, 140=mufflers 50=tips.
So I came in right under 400.
Old Mar 21, 2005 | 06:54 PM
kens64's Avatar
kens64
Depends on emissions in your area.
Can you weld? If so- a couple pieces of exhast pipe off the stock manifolds and some glasspacks will get you true duals for ~$100.
Old Mar 21, 2005 | 11:23 PM
MemOrex's Avatar
MemOrex
kens64 is right.
Since the stock Y-Pipe never joins into one pipe (the cat is dual-in), you can get some pipe and run out your own true duals. Thats what im doing hopefully soon.
Old Mar 22, 2005 | 04:05 PM
Saurian's Avatar
Saurian
My duals cost me 230 bucks. 150 dollars for pipes from just after the O2 sensor crossover (before the first Y-cat), 30 dollars for a pair of 24" glasspacks, and 50 bucks for my 4x22" stainless steel tips. Would have been 180 bucks straight up for pipes out the back, or 150 for straight pipes with no glasspacks. LOUD and proud.
