Sponsored by: Auxito
Desperate Last Call
Old Mar 27, 2005 | 05:16 PM
F2504x4's Avatar
F2504x4
Okay ...if you have a vacum leak the carb cleaner or wd-40 will be sucked in where it leaks causing a change in the RPM's, then you will have to fix or repair the leak with new gaskets or hoses etc etc... which ever is the case. Finding vacum leaks is not an easy task but can be done and they can cause a wide varity of symptoms.
Old Mar 27, 2005 | 06:23 PM
peppermrj's Avatar
peppermrj
The carb cleaner is sucked into the combustion chamber and effects the fuel charge,This changes the idle or sometimes will stall the truck,
Aahhhhh, My wife cleaned the keyboard and did not put all the keys back in the correct positions. Every time I hit the b I get a v,
F2504X4 Great smiley! Happy Easter all,
Old Mar 27, 2005 | 06:36 PM
peppermrj's Avatar
peppermrj
Be careful with carb cleaner it is flamable, I've never tried it but had a friend recommend using a hose as a makeshift stethascope and listening for the leak.
Old Mar 28, 2005 | 10:20 PM
odinsquare's Avatar
odinsquare
Alright I found a leak and took care of it. It manages to start now and stay started. That's good. Now, when I start it up, it still shakes, but the shaking last for more than a minute with RPM kind of low and if I put drive and hit the pedal it will surely go off. So I have to wait a little bit, then eventually start "kind" of normal. Also, one thing I notice is that it won't go beyond the 40mph, exactly there. I start going faster and then it shakes a little bit and won't go past the 40mph, that's strange... any ideas?
Texan481
2004 - 2008 F150
13
Jul 10, 2022 09:26 AM
yitzy
Aerostar
Feb 25, 2013 02:49 PM
Ricardo Lucatero
Jan 3, 2013 01:43 PM
yeomansjon
May 21, 2012 09:55 AM
JAMES GREGORY
Dec 21, 2011 04:50 PM
