CD4E automatic Escape Tranny
Old Mar 20, 2005 | 07:48 PM
nieking's Avatar
nieking
Question CD4E automatic Escape Tranny
I own an 02' Escape XLT 2WD and understand (from reading through this awesome knowledgebase) that the CD4E is the "weak link" in the 2001-2004 Ford Escape & Mazda Tribute. I have read countless postings here and elsewhere that state the best way to help the CD4E live longer is to:
1. Do frequent trany fluid flushes (Mercon only)
2. Add a larger aftermarket tranny oil cooler
3. Add an inline external tranny filter (ex. Permacool)
My question is this. Because it is such a pain to get to the stock tranny filter which I change every time I perform a flush, couldn't I simply gut the next stock filter out (remove the filter screen inside the plastic housing) and install an aftermarket inline filter such as Permacool, which can be changed with ease? May be this is crazy, but it seems like a practical solution to a somewhat difficult task.
Please comment.
Old Mar 21, 2005 | 08:04 AM
Casey's Avatar
Casey
I'd leave the internal filter alone and just change the outer filter. I've cut open filters that had more than 200k miles that didn't need to be changed.
If you're getting enough junk in the filter to plug it your trans is already toast. Changing the filter won't help.
Old Mar 21, 2005 | 08:38 AM
nieking's Avatar
nieking
Cd4e
Thank you for the info. It makes sense to leave the stock filter screen alone. Do you think an inline tranny filter will cause resistance to flow? Significant enough to be a problem that is?
Old Mar 21, 2005 | 09:01 AM
Casey's Avatar
Casey
Yes.
No, not when new, but get one that will bypass if the restriction gets high.
ta5150
Bio-diesel, Propane & Alternative Diesel Engine Fuels
83
Dec 1, 2021 08:13 AM
teletekman
Escape & Escape Hybrid
Jan 27, 2016 05:03 PM
springfieldescape
Aug 24, 2015 11:21 AM
jim henderson
Jun 9, 2004 12:21 AM
2shus
Oct 24, 2003 04:17 PM
