Engine Performace
Old Mar 20, 2005 | 05:19 PM
norfolk-southern's Avatar
norfolk-southern
Engine Performace
Hey, I have a 460 EFI in a 1995 F250, and I want to get some more horsepower out of it, but I'm not sure what cam to get that would give good power but maintain a daily driver status. I can stand a small rough idle, and I like the sound. I've put a K&N air intake system, and once I get some more money, I intend to get a BBK throttle body and headers. If you have any suggestions as to another throttle body or some type of headers it would be appreciated. The transmission is an E4OD.
Old Mar 22, 2005 | 12:25 PM
kevinrf250's Avatar
kevinrf250
I have a set of L&L headers on my 460 and they are very nice headers. I think BBK is the only company that makes a bigger throttle body. Comp cams makes a cam for the efi 460's, might give that a try. Hope this helps.
Old Mar 22, 2005 | 03:21 PM
norfolk-southern
thanks for the info, i had one other question, and thats what about lifters, what kind should i use for it, and will the cam mess with the computer for the engine. also i have heard about some air restrictor in the tubes from the filter, which i have replaced to the throttle body, is this true?
Old Mar 22, 2005 | 05:44 PM
kevinrf250's Avatar
kevinrf250
The restrictors in the air tube were mostly for noise reduction I think. my 460 never had them, I would think that to get the maximum benifit from the cam a custom chip would be needed to tell the computer what to do to take advantage of the upgrade.
Old Mar 22, 2005 | 07:11 PM
norfolk-southern
is there any chip out there that will not require me to use premium fuel with it, the price of regular is bad enough already
