Engine Compression Question?
Old Mar 20, 2005 | 04:51 PM
67buckeyeF100's Avatar
67buckeyeF100
What is the desireable compression for my '67 352. It has almost 77,000 miles on it, and I checked the compression yesterday and I there is 150 psig on all 8 cylinders.
Just wondering of this is a good number.
Thanks!
Old Mar 20, 2005 | 08:22 PM
76supercab2's Avatar
76supercab2
Sounds pretty good to me. And if all cylinders were close to the same value that's also good. Most shop manuals don't give a PSI reading for compression testing. Too many variables like cam timing etc. But they do spec that all cylinders must be within a % of each other. I think it's like 10% variation.
Old Mar 20, 2005 | 08:27 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yeah, that's pretty good... 150 is about dead-on...
My '79 Motors Truck Repair manual says for a '67 352, it should be 140. So you're good
Old Mar 20, 2005 | 08:39 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Yep...Sounds good to me..as long as the highest cylinder and the lowest are within 10% of each other your good to go!!
Russ
Old Mar 21, 2005 | 11:53 AM
67buckeyeF100
Thanks guys!
I was really surprised at the results, from the age of the truck and the engine.
Old Mar 22, 2005 | 11:05 AM
krewat's Avatar
krewat
Yeah, that is pretty good! And like RapidRuss said, 10% variation is the max, so getting 150 on every cylinder is amazing...
Good luck with it!
